ging Posted September 21, 2010 Share Posted September 21, 2010 HELLO GUYS MY SPEEDO HAS STOPED WORKING CAN ANY ONE TELL ME WHAT MIGHT BE WRONG WITH IT PLEASE .ALSO WERE CAN I GET A CHEAP DEP EXAUST THANKS DAVE P.S ITS A DT125R 2002 Link to comment Share on other sites More sharing options...
chris66 Posted September 21, 2010 Share Posted September 21, 2010 the cable is the first thing to check , its probably snapped inside. unscrew it from the front wheel. chris Link to comment Share on other sites More sharing options...
ging Posted September 21, 2010 Author Share Posted September 21, 2010 the cable is the first thing to check , its probably snapped inside. unscrew it from the front wheel. chris cheers mate u think it might be the cable then Link to comment Share on other sites More sharing options...
chris66 Posted September 21, 2010 Share Posted September 21, 2010 if you unscrew the cable from both ends and turn the inner cable see if it turns at the other end. if it doesn't then the cable has snaped if it turns then connect it back to the clock connect the other end to a drill. when you operate the drill if the speedo moves its the drive in the wheel that's at fault. chris Link to comment Share on other sites More sharing options...
ging Posted September 22, 2010 Author Share Posted September 22, 2010 if you unscrew the cable from both ends and turn the inner cable see if it turns at the other end. if it doesn't then the cable has snaped if it turns then connect it back to the clock connect the other end to a drill. when you operate the drill if the speedo moves its the drive in the wheel that's at fault. chris thanks mate Link to comment Share on other sites More sharing options...
