September 20, 201015 yr HELLO I was thinking about gettin a digital speedo for my 2001 dtr but was wondering if there is any way of gettin a fule gadge fitted in it ? Thanks as always Connor
September 20, 201015 yr It would not be worth it. Anyway fuel tank is prob to small to hold one. Use your trip meter, put it to zero every time ya fill up then ya will know when your comming near empty. simples
September 20, 201015 yr HELLO I was thinking about gettin a digital speedo for my 2001 dtr but was wondering if there is any way of gettin a fule gadge fitted in it ? Thanks as always Connor Digitals are expensive, but can be transfered to future bikes should you upgrade, so keep your old speedo . A fuel gauge would be a pita to fit and not worth it imo. You would need to modify the tank to take a fuel level sender unit and the necessary wiring to suit. Personally, I would prefer to push my bike 3 miles to the petrol station again, twice, than go through the hassle of fitting one. Besides whats up with the reserve, I can get around 30-35 miles from it, which is more than enough to get me to a fuel station, should i remember I'm on reserve that is . Edit: Dammit Pat, you been having typing lessons again, keep beating me to it
September 20, 201015 yr Edit: Dammit Pat, you been having typing lessons again, keep beating me to it Yep, gettin 15 lessons a day
September 20, 201015 yr Ya can get a digital spedo for a mountain-bike for cheep and it works ok ish if ya set it up right. I put one on my DT just to have a clock for my trip to Squires. Unfortunatly when i went over 70mph i think i blew it up, i guess not meant for that speed,,,,,,,but the good news the clock still works.
September 20, 201015 yr Author Ya can get a digital spedo for a mountain-bike for cheep and it works ok ish if ya set it up right. I put one on my DT just to have a clock for my trip to Squires. Unfortunatly when i went over 70mph i think i blew it up, i guess not meant for that speed,,,,,,,but the good news the clock still works. I think im goin to get a proper 1 Also mate my bike struggles to get over 60-65mph iv taken out the reed, but not the exhusts restriction i was wondering if there is anything else to do
September 20, 201015 yr I think im goin to get a proper 1 Also mate my bike struggles to get over 60-65mph iv taken out the reed, but not the exhusts restriction i was wondering if there is anything else to do Let me get this right, You have taken out the reed and it still runs? Edit, Not thinking right, thought for a minute you meant the reed valves
September 20, 201015 yr Author Let me get this right, You have taken out the reed and it still runs? Edit, Not thinking right, thought for a minute you meant the reed valves AHAH no just un restricted it
September 20, 201015 yr The reed switch will let the reves rev full, But with the exhaust not done the engine cant get rid of the gasses fast enough so this retards the engine, Therefor ya have to do the 2 things. Take your exhaust off and have a look ta see what kind of restriction it has. You have a 2001 bike so probably in the neck of it where it bolts to the exhaust port. Be carefull cutting it out,,,,,,,,,,,it seemes from another post someone has made a balls of there pipe.
September 20, 201015 yr Author The reed switch will let the reves rev full, But with the exhaust not done the engine cant get rid of the gasses fast enough so this retards the engine, Therefor ya have to do the 2 things. Take your exhaust off and have a look ta see what kind of restriction it has. You have a 2001 bike so probably in the neck of it where it bolts to the exhaust port. Be carefull cutting it out,,,,,,,,,,,it seemes from another post someone has made a balls of there pipe. I was goin to get a Big One Exhust soon so i was just goin to leave it for know, do you think i should re attach the reed to stop damage? thanks
September 20, 201015 yr do you think i should re attach the reed to stop damage? thanks It all depends if you can stop yourself getting hooked on redlining every where, Its harder than you think belive me
September 20, 201015 yr I was goin to get a Big One Exhust soon so i was just goin to leave it for know, do you think i should re attach the reed to stop damage? thanks No, reed left out will be fine. If ya get a Full system Big One, then you will have to rejet your carb.
September 20, 201015 yr Author No, reed left out will be fine. If ya get a Full system Big One, then you will have to rejet your carb. Is it difficult to rejet? Also How
September 20, 201015 yr Is it difficult to rejet? Also How Hard ta tell ya over a computer ! Carb off,,,,take out main jet,,,,,,put in slightly bigger jet,,,,,,,carb on,,,,,,,play arround with air screw,,,,,,,then play arround with idle screw. Not as easy as sounds if ya dont haave an engine head ! Nite now
September 21, 201015 yr Here's a solution....... Buy yourself a Garmin Zumo 500/550. You get a digital speed readout (and accurate, not like the crap on the bike) and also a fuel gauge. The Zumo will even tell you when you're fuel is running low (obviously there is some setting up to do). You also get the added benefit of knowing where you are! and if you choose, you can use it to find places too...... But to be honest, I'd just use the trip and figure out how many miles you get on a tank, For a good digital speedo, that is very accurate (and still requires setting up ) then Trail Tech have some superb units that are very small here -> Trail Tech I have a trailtech unit in my TTR after the OE speedo fell apart...
