Ficky Posted September 20, 2010 Share Posted September 20, 2010 Hi Team I have just pulled down the xs motor and wish to know if the markings under the skert mean anything (3 & 4 ) are this size if so do we know the size needs bore done so looking at size ? any help would be good Cheers Chris Link to comment Share on other sites More sharing options...
Moderator drewpy Posted September 20, 2010 Moderator Share Posted September 20, 2010 size is usually stamped on the front top. nothing there means standard bore Link to comment Share on other sites More sharing options...
saltcreekknife Posted September 21, 2010 Share Posted September 21, 2010 Hi Team I have just pulled down the xs motor and wish to know if the markings under the skert mean anything (3 & 4 ) are this size if so do we know the size needs bore done so looking at size ? any help would be good Cheers Chris I just put a new piston in my dt175. There were no markings relating to size on piston I took out. I had to measure with a caliper. Once you have the size you can look up if it is standard, oversize, etc. If you have a shop in mind that is doing the re-bore, they would probably measure for you if you do not have caliper. Good luck. Link to comment Share on other sites More sharing options...
Ficky Posted September 29, 2010 Author Share Posted September 29, 2010 Hi Team I have messured the piston and yes they are standard, so have ordered 2 new .25 oversize pistons and rings will send bore in soon for rebore . Thanks for the help Link to comment Share on other sites More sharing options...
