This post is 4738 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
there's a blag by a TX/XS 500 enthusiast which may help
  • 1 year later...
Speed and Sport Yamaha has inventory for many XS500 parts, but are probably the most expensive option. I bought all my engine gaskets on ebay, from several different sellers.
Once on ebay in motorcycle parts, search for "XS500 + gasket" ( no quotes, but a space before and after the + sign.)
For carburetor parts,see MIkesXs.com . (USA) They are a XS650 specialist, but the carburetors for some years have parts that are common to the XS650 and XS500.. MikesXs will usually list the OEM part number, so you can check that way. Also, they have pictures of the parts, and you can doublecheck that way. I bought choke gaskets, o-rings, float bowl gaskets there.
If you need anything EXCEPT engine parts, check the XS650 for equivalent parts. Since you are in the UK, perhaps there is a good Xs650 specialist there?
