My TZR splutters and dies !
Hi guys , I have been here a while now , and have had loads of help too ! :)
I have a 2004 TZR 50 and have had her on the road about a month now ( after a whole load of problems ) !
To start with she would bog down and splutter at around 6500 rpm , but after around 1-2 seconds it would carry on to rev up . This problem slowly got worse over time , until now she intermittently cuts out while riding (with the choke off) . If I put the choke on she'll regain power again and rev freely again and run fine , however after around 5-10 seconds she will die completely and refuse to run at all ....unless I take the choke off, after a further 5-10 seconds im back to the same spluttering problem :\ ?!?! How bizarre so she will run with the choke and with out the choke , but also die with the choke and without the choke ?
Any help would be vastly appreciated :)
Thanks Again
Jordan
Okay just checked the float bowl , the drain screw was really tight, so I drained it and flushed it through with a bit of fuel.
Its helped partially, she runs fine with the choke on ( still splutters with the choke off ) and there is a massive drop in performance !
Before posting on here I gave the air filter a good clean , so do you think it could be the air fuel mixture ? Worth up jetting ?
Thanks again oldgitonabike :) This isn't the first time you've pointed me in the right direction :)
Jordan
Was it good before the air filter clean?
What type of air filter is it?
How did you clean it?
Did you oil it before re-fitting?
You say it splutters with the choke off...is this with a cold engine of a warm engine?..
It was spluttering before cleaning the filter , that's why I cleaned it , i cleaned it by flushing hot water through it , before drying it, hoovering it and cleaning it with Carb cleaner :)
Its a 21mm K&N style cone air filter if that helps, I cant say I did oil it before refitting it, but i never have really , just tightened it up really tight !
She still splutters when warm , not as much , but still very noticeable !
Hope this helps
Jordan
Does this spluttering only happen when the bike is in high revs ?
Can you start the bike from cold with choke and then when its a bit warm put the choke off, will the bike idle now for a while ?
