September 16, 201015 yr i was riding me dt around the paddock then i let it sit over night then i started it in the morning it went for around 5-10 mins then it died i recently put a new air filter in it after it wouldnt start i pulled the carby out and cleaned it the fuel filter was block so i cleaned that and i put it back together and it still wont start it did start for around 5 seconds when it stopped it sounded like it was runny out of fuel Please Help thanks Dylan
September 16, 201015 yr Sounds like a fuel blockage in the carb, did you strip it and clean all the jets and journals?
September 18, 201015 yr Author Sounds like a fuel blockage in the carb, did you strip it and clean all the jets and journals? thanks mate i got it going
November 11, 201014 yr Author thanks mate i got it going hay now its not going again it went for a couple of mins then died so i pulled the sparkyplug owt and it was oiled up so i put i new one in then it was floaded after a couple of mine ofter been started i think it runing to rich im not sore im think about getn it fixed then by a 4 stroke
