hi im new to this ive a dt125r year 2000 after winter i tried to start my bike and no joy i checked the plug and it was wet with oil could anyone tell me what has to be done to stop it it starts when i jump it on a hill but dosent kick start or take over right any suggestions it would be great thanks.
HI welcome,,," its nearly winter again :unsure: ,,, Fresh fuel, and a new plug, for starters, if its starting with a bump [ push] seems its not a strong spark off kickstartn, ;)
put new plug in and fuel it seems to be mixing too much oil
Hi" you say oil , is the new plug fowled,? , i trust your on oil injection ? & not pre-mix, have you a manual. if so , check the clearance on oil pump adjustment screw. or line up marks, is the choke stuck on ,?
, :mellow:
ive the choke of il av to look at the manual to find out where the oil pump screw is cheers
