DT50MX slips from 2nd gear back into neautral
Hi my dt50mx keeps slipping back out of 2nd gear any one know how to solve this problem thanks Dan
worn detent plunger/selector forks i imagine, my DT had a habit of doing that if i thrashed it and it got upset. also make sure the clutch is fully pulled in and you push the gear change lever fully upwards as i found i was pulling the clutch lever in so the clutch was still lightly engaged (smoother transition) and tapping the lever upwards
