oil light
advice needed got a 1ooo exup on a j plate had no problems with it till monday oil light came on around 80-90 then went off when went slower does any one know if there is any problems with these engines only done it twice
Hi Zubes
I had the same issue with my FZR600, wrong grade of oil
what oil you using ? is it the correct grade ,
I would change the oil and filter,and fill to the correct level then you know you are ok , then keep an eye on it ,could be just the oil sensor, if its starts again and the sensors fine , more likely to be the pump failing , if it is failing the light will stay on longer and longer.
could be a blip in the ECU , take the battery off for ten minutes ,reconnect then go for a ride
do the oil change first and see how you get on
cheers
Al
Hi Zubes
cheers
Al
cheers just doing oil chang oil looks like it may be to thin and dirty so start with that cheers for ya help
