Posted September 1, 201014 yr I've been trying to get my old bike running, but I'm not getting spark on the left cylinder. Its getting a nice spark on the right cylinder, but the left cylinder just sparks once when you hit the start button and once when you let off. I tried replacing the coil, but the new one acted the same. I checked the wiring connections and everything looked ok. Could this be in the ignition control box or is there somewhere else I should look? Thanks for your help.
September 1, 201014 yr Moderator I've been trying to get my old bike running, but I'm not getting spark on the left cylinder. Its getting a nice spark on the right cylinder, but the left cylinder just sparks once when you hit the start button and once when you let off. I tried replacing the coil, but the new one acted the same. I checked the wiring connections and everything looked ok. Could this be in the ignition control box or is there somewhere else I should look? Thanks for your help. does sound like the TCI. have you checked earthing/HT wires could be a loose wire from the trigger point
September 3, 201014 yr Author Suppose I do have some loose wires at the trigger, where would I find this to check it. I have tried downloading the XS manual but haven't had any luck. Thanks for your help.
