I just finished getting an 81 DT175 running. After it sat overnight, I noticed a little gas running out of the carb's overflow tube. (a 1" drip area on the floor, not much) I replaced the floatbowl needle. Could it be a faulty needle or do I need to check the floatbowl level?
Also, how do you clean the white plastic fenders. They are stained, and I do not want to damage the surface. Any thoughts?
Thanks
the leak could be float level but more likely your needle valve not seating tight, perhaps a little dirt.
i have always used a little t cut on white plastics.
mine's dripping too, even with a new(ish) valve in it!
I had it out yesterday but it looked ok, I raised the float level from the recommended 21mm to 23mm...and it still leaks a bit. I will be getting a new valve next :angry:
Yeah try T Cut paint restorer or whatever you have on the East side of the Altlantic. B)
for plastics I use Peeks polish, good stuff.
as far as needle valves, they are finiky buggers, I had to mess with mine right up to the day of the ride to Colraine from manchester.
I've not heard of the products you guys have mentioned. I will check around on the internet to see if they are available. If not, I will find something similar.
I will play around with the needle valve tomorrow and see what I can figure out
Thanks
Try any UPVC window restorer on the plastics
