August 22, 201015 yr i was riding my yb100 saw a ferrari and knocked it down a gear instead of up it made a horrible noise and started backfiring and lagging cant think of any word to describe it when i am going along it pulls back for less than a second the stops for another half sec then does it again. left it for a bit not backfiring but at 40ish the bike does the lagging thing just wondered if you knew what it could be maybe thanks webi edit: i can actually physically feel it pulling back is this misfiring?
August 22, 201015 yr i was riding my yb100 saw a ferrari and knocked it down a gear instead of up it made a horrible noise and started backfiring and lagging cant think of any word to describe it when i am going along it pulls back for less than a second the stops for another half sec then does it again. left it for a bit not backfiring but at 40ish the bike does the lagging thing just wondered if you knew what it could be maybe thanks webi edit: i can actually physically feel it pulling back is this misfiring? Epic Sorry i can't help you, but thank you for making my day. Vez.
August 22, 201015 yr Author Epic yer i found it quite funny lol out of no where a red ferrari pops out edit: think i have found the problem the points are closed
August 24, 201015 yr gap them with a rizla paper(old school).same with the plugs... You should only use a Rizla for setting the "breaking" of the points !! Preferably a "blue" rizla paper as they are the thinest Set the "gap" to the recommended setting with feeler gauges. (the "old school" trick here was to use a "cigarette packet" to set the gap, same with the spark plug) Good luck Em
August 24, 201015 yr You should only use a Rizla for setting the "breaking" of the points !! Preferably a "blue" rizla paper as they are the thinest Set the "gap" to the recommended setting with feeler gauges. (the "old school" trick here was to use a "cigarette packet" to set the gap, same with the spark plug) Good luck Em Damn! a cigarette packet, thats one huge gap for a plug
August 24, 201015 yr Damn! a cigarette packet, thats one huge gap for a plug OK, smart arse Maybe I should have been a bit more specific THE CARDBOARD FROM A CIGARETTE PACKET, which was about 15 thou (Park Drive/Senior Service etc.) Which should give a large enough gap to allow a spark to be generated, THERE IS NO RELIABLE SUBSTITUTE FOR THE MANUFACTURERS RECOMMENDED SETTINGS, however as a "get you home" bodge, the aforementioned method will "usually" suffice Em By the way, shouldn't this be in the "Workshop" forum
August 24, 201015 yr Author right guys thanks for your replies set the plug gap with feeler gauges was 0.014 inch i think but earlier i was going along it backfired (sounded like it was spitting from the exhaust a sort of splutter i guess) and died had to run and bump it 3 times to get it to clear think it flooded it then also did it when entering my village but didnt bog down and flood i think it is flooding anyway not really sure what started this was i was doing 25-30 and instead of going into 3rd gear i knocked it down into 1st
