i was riding my yb100 saw a ferrari and knocked it down a gear instead of up it made a horrible noise and started backfiring and lagging cant think of any word to describe it when i am going along it pulls back for less than a second the stops for another half sec then does it again.
left it for a bit not backfiring but at 40ish the bike does the lagging thing just wondered if you knew what it could be maybe
thanks webi
edit: i can actually physically feel it pulling back is this misfiring?
thanks webi
Epic :lol::lol::lol:
Sorry i can't help you, but thank you for making my day.
Vez.
yer i found it quite funny lol out of no where a red ferrari pops out :lol:
edit: think i have found the problem the points are closed ;)
gap them with a rizla paper(old school).same with the plugs...
You should only use a Rizla for setting the "breaking" of the points !! Preferably a "blue" rizla paper as they are the thinest :D
Set the "gap" to the recommended setting with feeler gauges.
(the "old school" trick here was to use a "cigarette packet" to set the gap, same with the spark plug)
Good luck
Em B)
Good luck
Em B)
Damn! a cigarette packet, thats one huge gap for a plug :o
OK, smart arse :mellow:
Maybe I should have been a bit more specific :unsure:
THE CARDBOARD FROM A CIGARETTE PACKET, which was about 15 thou
(Park Drive/Senior Service etc.)
Which should give a large enough gap to allow a spark to be generated,
THERE IS NO RELIABLE SUBSTITUTE FOR THE MANUFACTURERS RECOMMENDED SETTINGS, however as a "get you home" bodge, the aforementioned method will "usually" suffice :thumb:
Em B)
By the way, shouldn't this be in the "Workshop" forum :unsure:
right guys thanks for your replies set the plug gap with feeler gauges was 0.014 inch i think but earlier i was going along it backfired (sounded like it was spitting from the exhaust a sort of splutter i guess) and died had to run and bump it 3 times to get it to clear think it flooded it then also did it when entering my village but didnt bog down and flood
i think it is flooding anyway not really sure what started this was i was doing 25-30 and instead of going into 3rd gear i knocked it down into 1st :angry:
