Posted August 19, 201015 yr the yb100s a bit smokey when standing started (not moving). and tick over non exictent any ideas im abit stumpded on mikuni carbs.
August 20, 201015 yr Moderator the yb100s a bit smokey when standing started (not moving). and tick over non exictent any ideas im abit stumpded on mikuni carbs. Does the smoke clear after a good run, is it blue smoke ie 2T oil smoke. Are you saying bit wont idle? Turn the throttle stop screw in a bit at a time until it does, set the mixture screw about 1 1/2 turns out (a guess)
August 20, 201015 yr do you have any trouble starting the bike and is the gearbox oil going down it could be crank seals. the mixture screw is 1/2 turns out on my manual
August 24, 201015 yr Author Does the smoke clear after a good run, is it blue smoke ie 2T oil smoke. Are you saying bit wont idle? Turn the throttle stop screw in a bit at a time until it does, set the mixture screw about 1 1/2 turns out (a guess) not able to give a run, private land needed to run its less smokey now
August 24, 201015 yr Author do you have any trouble starting the bike and is the gearbox oil going down it could be crank seals. the mixture screw is 1/2 turns out on my manual no problems on starting and ok ill try that
