full beam Indicator light always on... light doesnt work
Zackw
This post is 5145 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
my full beam Indicator light is always even when i switch the light on or off on however the light doesnt work, any ideas? when i remove the bulb the switch goes off. think i should replace the bulb?
If there is power to the light...and check that, then replace it and see what happens.
yeah theres power to the bulb, when the switch is on theres power to the green and when its off theres power to the yellow, cant find a place that sells my bulb anywhere. its a HS1
Sounds like a bad bulb/earth. The electric is tracking through the other fillament looking for an earth and the main beam lamp is it.
Try a new bulb first, (always) and then check the earth.
