using alot of oil
hi i have a yamaha yb100 1988 and when i top up the oil it only lasts for about 5 gallons does this sound right to you?
i take it you mean two stroke oil.
one litre bottle at aprox 40/1 mix should last 40 litres
about 8 gallons.
if your using half litre bottle of oil then your about right
if you mean you are compleatly filling the two stroke container then you are using much to much
