August 9, 201015 yr On the inlet side of the carb, there is a small screw with a spring inside. What does this adjust?
August 9, 201015 yr On the inlet side of the carb, there is a small screw with a spring inside. What does this adjust? Sounds like it might be the air/fuel mixture screw
August 9, 201015 yr Moderator yes it does, you need to get a manual it will tell you where to adjust it to. As a rough idea though they are usually 1 and 1/2 turns out from gently closed.
