Posted August 8, 201015 yr Hi All, Can any of you clever chaps out there help. I need to make the 535 rev less at motorway speeds, I have fitted a larger tyre which has helped a bit and made the handling better, what i would like to do is alter the gearing on the rear wheel dif. Any suggestions. Thanks in advance and be safe
August 9, 201015 yr Hi All, Can any of you clever chaps out there help. I need to make the 535 rev less at motorway speeds, I have fitted a larger tyre which has helped a bit and made the handling better, what i would like to do is alter the gearing on the rear wheel dif. Any suggestions. Thanks in advance and be safe If you would like your bike to run at lower RPMs at highway speeds you can either get a larger (more teeth) front sprocket or smaller (fewer teeth) rear sprocket. I Hope that helps.
August 9, 201015 yr He'll have a big problem there Pepper, your advice would be sound for a chain driven bike but from memory, I believe the Virago is SHAFT driven I think you've already done what you can Trevor with the bigger tyre Maybe a different set of Dif gears is available but its my guess your stuck with what you've got :-( Em By the way Trevor, an introduction would be polite I know, I should talk
August 9, 201015 yr He'll have a big problem there Pepper, your advice would be sound for a chain driven bike but from memory, I believe the Virago is SHAFT driven That's embarrassing In that case I am not sure what else can be done. Good luck
