indicator problem
DomT
This post is 5017 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
my 1981 yb100 (1 owner from new) been standing has a slight electrical problemo, headlight doesnt light up and indicators dont flash, only light up
help? advice?
regards Dom
Hi Dom
The headlight will only work with the bike running as it is powered from the flywheel magneto. As to the indicators they are always a bit of a problem on this bike - my experience is that a) They run better with the engine on! B) You need to have a good (fully charged battery) c) As the electrical system works on an earth return system the 'ground' on the indicators needs to be good for them to work well. I have never been able to get mine to work terribly successfully just on the battery - joys of the 6v system that was never really designed to power indicators I suppose.....
:huh:
Link to comment
Share on other sites
if you fitted led indicators they require less power to work so in theory should work better
Hi Dom
:huh:
Link to comment
  • Recently Browsing
