Posted August 6, 201015 yr Hi Team I have been working on this bike for a little while and have just done a compresion test and one side is 110 PSI the other 120PSI with a few drops of oil it changes to 140 PSI and 180 PSI so looking at doing the rings and valves it also blows smoke after a long run. Any advice would be great, also doing the cam Chain at the same time. Cheers Chris
August 6, 201015 yr How fast are you going in that picture? Your posture leads me to believe around 90 or so.
August 6, 201015 yr Author How fast are you going in that picture? Your posture leads me to believe around 90 or so. Not sure as the wind in my eyes makes them water so much I cant read the speedo, Cheers Chris
