My New Bike, what model is it though?
hey guys am new one here and not sure what type of bike ive bought its am import ya see not entirely sure,
its either a fz 400 fazer? or a xj 400 or xjr 400 im not sure, has a exhasuton each side and need a new one help plese :(
thanks guys
As I said in your other thread, it's an XJ400S Diversion.
http://homepages.pavilion.co.uk/ilange/yamgal01.htm
Found this.
• 1983 Yamaha XJ 400
Model Yamaha XJ 400 1983
Motorcycle Style: Standard
Engine
Type: 398 cc, 4 Stroke - Air Cooled - Inline Four
Engine Bore and Stroke: 51 mm x 48.8 mm
Valves 2 valves/cylinder
Claimed Horsepower
: 46 hp (34.3 kW) @ 10000 rpm
Maximum Torque: 34.6 Nm (25.5 ft. lbs) @ 8500 rpm
Transmission type: 6 speed
Final Drive: Chain
Tire
- Front: 3.00-18
Tire - Rear: 110/90-18
Brakes - Front: dual 240 mm discs with 2-piston calipers
Brakes - Rear: 180 mm drum
Fuel Capacity: 15 l (4 Gal)
Dry Weight (without fluids): 166 kg (366 pounds)
you's two are legends i know absoloutly nothing about bikes so where or how could i repair the exhaust its split halfway from the end of the can and where it bends up ?
thanks again folks
So far you have learned a few things about your motorcycle, but the learning has only just begun. Have another look at.....
and see if you can learn something from that ! Also slow down, If you rush into motorcyling the way you have rushed into the forum, you will only become another statistic.
hahaha cheers for the vid a get it all the time, yer a won a holiday at work and went on a track in la manga called cartegana used a honda vrf 400 in june so thats what got me into bikes, my lasses dad had this next to his ferrari was like aye its me mates he wants £400 for the bike so a thought what the hell a booked me theory yesterday and have to waait til am 21 before a can do me direct access, this is me on that bike though, below...
oh and that link didnt work :(
