hey guys am new one here and not sure what type of bike ive bought its am import ya see not entirely sure,
its either a fz 400 fazer? or a xj 400 or xjr 400 im not sure, has a exhasuton each side and need a new one help plese :(
thanks guys
As I said in your other thread, it's an XJ400S Diversion.
http://homepages.pavilion.co.uk/ilange/yamgal01.htm
Found this.
• 1983 Yamaha XJ 400
Model Yamaha XJ 400 1983
Motorcycle Style: Standard
Engine
Type: 398 cc, 4 Stroke - Air Cooled - Inline Four
Engine Bore and Stroke: 51 mm x 48.8 mm
Valves 2 valves/cylinder
Claimed Horsepower
: 46 hp (34.3 kW) @ 10000 rpm
Maximum Torque: 34.6 Nm (25.5 ft. lbs) @ 8500 rpm
Transmission type: 6 speed
Final Drive: Chain
Tire
- Front: 3.00-18
Tire - Rear: 110/90-18
Brakes - Front: dual 240 mm discs with 2-piston calipers
Brakes - Rear: 180 mm drum
Fuel Capacity: 15 l (4 Gal)
Dry Weight (without fluids): 166 kg (366 pounds)
you's two are legends i know absoloutly nothing about bikes so where or how could i repair the exhaust its split halfway from the end of the can and where it bends up ?
thanks again folks
So far you have learned a few things about your motorcycle, but the learning has only just begun. Have another look at.....
and see if you can learn something from that ! Also slow down, If you rush into motorcyling the way you have rushed into the forum, you will only become another statistic.
hahaha cheers for the vid a get it all the time, yer a won a holiday at work and went on a track in la manga called cartegana used a honda vrf 400 in june so thats what got me into bikes, my lasses dad had this next to his ferrari was like aye its me mates he wants £400 for the bike so a thought what the hell a booked me theory yesterday and have to waait til am 21 before a can do me direct access, this is me on that bike though, below...
oh and that link didnt work :(
