Front fork oil seals
Hya folks, another query for the guru's :unsure:
My 1982 (Import 1st registered in UK 1988) is in need of new fork seals.
Problem is, I cant find the sizes in any of the parts manuals which I have ?
Does anyone have the sizes ? If not, where I could find out ?
I have had the vernier caliper on the stanchion and as far as I can be, I'm sure they measure 32mm.
I have seen various seals for sale on Ebay but none of this size !
33mm,42mm & some with no sizes listed at all ! just a listing for all SR's 1980 to 1994 ?
Has anyone got a definitive answer ?
Photos of the bike are on the "Garage" section of this site if that may be of any help ?
By the way, can anyone tell me, from looking at the photos, which "model" I have acquired ?
Many thanks for the info already provided.
Ciao4now
Em B)
Thanks guys :blush:
I knew there was something I'd forgotten :rolleyes:
Frame number.....3Y6103865
Engine number....3Y6103865
The swinging arm spindle is seized into the rear of the crankcases, which is why I had to sandblast the motor in the frame :wacko:
By the way root, the "Motorcyclepro" link lists the seals as 33mm !
The other site seems to require a part number but as I'm not certain which model I have yet, its a bit of a "dead end" at the moment. But thanks anyway for the time and trouble you've gone to to provide the links :thumb:
My vernier says 32mm + or - .02mm ? its certainly not 1mm out :icon_confused:
I'm sure its reading correctly (its digital) and I measured the stanchion between the yokes, where there is almost no possibility of any wear taking place, so what do you think ?
Have I got an "oddball" ?
The forks seem to be original fittment, they are a "snug fit" in the yokes so I'm fairly sure they were on it when it left the factory.
Ciao4now
Em B)
