Posted July 27, 201015 yr Hya folks, another query for the guru's My 1982 (Import 1st registered in UK 1988) is in need of new fork seals. Problem is, I cant find the sizes in any of the parts manuals which I have ? Does anyone have the sizes ? If not, where I could find out ? I have had the vernier caliper on the stanchion and as far as I can be, I'm sure they measure 32mm. I have seen various seals for sale on Ebay but none of this size ! 33mm,42mm & some with no sizes listed at all ! just a listing for all SR's 1980 to 1994 ? Has anyone got a definitive answer ? Photos of the bike are on the "Garage" section of this site if that may be of any help ? By the way, can anyone tell me, from looking at the photos, which "model" I have acquired ? Many thanks for the info already provided. Ciao4now Em
July 27, 201015 yr Hi this might help ? http://www.cmsnl.com/products/oil-seal_2k52314500/ or this http://motorcycleproducts.co.uk/catalogue/fork-seals-yamaha-sr250-197984-p-165938.html
July 27, 201015 yr Author Thanks guys I knew there was something I'd forgotten Frame number.....3Y6103865 Engine number....3Y6103865 The swinging arm spindle is seized into the rear of the crankcases, which is why I had to sandblast the motor in the frame By the way root, the "Motorcyclepro" link lists the seals as 33mm ! The other site seems to require a part number but as I'm not certain which model I have yet, its a bit of a "dead end" at the moment. But thanks anyway for the time and trouble you've gone to to provide the links My vernier says 32mm + or - .02mm ? its certainly not 1mm out I'm sure its reading correctly (its digital) and I measured the stanchion between the yokes, where there is almost no possibility of any wear taking place, so what do you think ? Have I got an "oddball" ? The forks seem to be original fittment, they are a "snug fit" in the yokes so I'm fairly sure they were on it when it left the factory. Ciao4now Em
