spacemanps Posted July 27, 2010 Posted July 27, 2010 http://www.youtube.com/watch?v=ISzwJeLWlME 1976 Yamaha xs360... if you listen, you will hear the bike idle fine, but once you rev it a little bit, it will keep going and just sit at about 3-4 rpm. You have to use the kill switch to slow it down to a normal idle. Just so you know, its not the throttle cable (checked). thanks for any help!!
Moderator drewpy Posted July 27, 2010 Moderator Posted July 27, 2010 1976 Yamaha xs360... if you listen, you will hear the bike idle fine, but once you rev it a little bit, it will keep going and just sit at about 3-4 rpm. You have to use the kill switch to slow it down to a normal idle. Just so you know, its not the throttle cable (checked). thanks for any help!! if you did a forum search, you would find out that the carb mix is lean. been mentioned many many times before!!
HoughMade Posted July 27, 2010 Posted July 27, 2010 Yep- lean. Turn the screws in to a light seat, then turn them out 3.5 turns and adjust from there. Yes, I know the factory manual says 1.5 turns....I don't know what they were smoking- 3.5 to start.
spacemanps Posted July 27, 2010 Author Posted July 27, 2010 okay thanks guys, i will test it out tonight.. keepin my fingers crosses... a friend thought it was the timing advance...
johnsnownw Posted July 27, 2010 Posted July 27, 2010 okay thanks guys, i will test it out tonight.. keepin my fingers crosses... a friend thought it was the timing advance... Also, make sure you don't have your idle screw turned in too much. That will also cause the throttle to stick at higher revs.
spacemanps Posted July 27, 2010 Author Posted July 27, 2010 temp solution was the 3.5 turn on the low speed mixture screw. But after riding 30 min riding, idle started to be too low.. so when i raised(idle) it the problem came back. guessing i need bigger low speed jets? because 3.5 turns helped a bit but not enough (the rpm would stay high but drop slowly down) Background info- i just changed the stock air box's to pod filters. Current jets: Low- 15 high- 135 Opinion jets needed:?? Low- 20 high-140
dtmf Posted July 29, 2010 Posted July 29, 2010 bump for input... pull the carb's clean'm real good and go up 1 size on the jet's . reseal the intake manifold's to the head's to make shure you don't have any leak's there . re-install the carb's and sync them up and go from there ...
spacemanps Posted July 29, 2010 Author Posted July 29, 2010 pull the carb's clean'm real good and go up 1 size on the jet's . reseal the intake manifold's to the head's to make shure you don't have any leak's there . re-install the carb's and sync them up and go from there ... i went up a bit more than one size but i hope it will end up working out..
dice1649 Posted August 8, 2010 Posted August 8, 2010 i went up a bit more than one size but i hope it will end up working out.. hey buddy i sent you a PM, did you get it?
