xs500 Carbs
wildturkey
This post is 5236 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
This may be a silly question but i have been looking all over the place and I cannot find a 77 xs500 specific rebuild kit for the carbs.
I believe I have the 38mm mikunis in it.
I have also seen that there are oversized jet rebuild kits that i think fit the 38's is this a good idea?
I am planning on putting a higher flow exhaust and air filters on the bike which I have heard you need to make the higher flow jets work properly.
Link to comment
Share on other sites
Haver you checked with Speed & Sport Yamaha for carb kits? They have a website and seem to have lots of parts for old Yamahas.
You will need to re-jet for both of those things. You should get both and then re-jet, as you'll probably have to change again if you put one on then the other.
You can also get all the necessary parts from here:
http://www.mikesxs.net/products-37.html#products
I also suggest getting new gaskets if you're going to be taking the carbs apart, which you can also purchase from MikesXS.
The parts are relatively cheap, so you can purchase 2 different sized jets and see what fits your setup best.
Good Luck.
Link to comment
  • Recently Browsing
