Paulwhite Posted July 16, 2010 Posted July 16, 2010 hi peeps iv got to take the crank out of me xv 125 engine but cant get the clutch or the magnet off, anyone got a manual or some instruction? the clutch has a wierd bolt and nut in the middle that both undo, and the magnet on the other side wont budge cause its a taperd, keyway shaft. cheers. .Paul.
Vez Posted July 16, 2010 Posted July 16, 2010 hi peeps iv got to take the crank out of me xv 125 engine but cant get the clutch or the magnet off, anyone got a manual or some instruction? the clutch has a wierd bolt and nut in the middle that both undo, and the magnet on the other side wont budge cause its a taperd, keyway shaft. cheers. .Paul. If its anything like most i have worked on you will possibly need a flywheel puller for the magnet (flywheel). Although i have used a rubber mallet to gently tap the flywheel whilst pulling it away from the bike, but i have broken magnets using this method. It best if you get a puller. They come in different shapes and sizes and are not to expensive. Below is the type i have. And the part of the clutch you are talking about is for possibly for adjustment, if you remove the springs it should come off,and the part you talked about should be attached to a long bar that protrudes into the shaft in the middle with a ball bearing after it that may roll out. Friction can hold the outer plate on quite well. HTH Vez
Paulwhite Posted July 16, 2010 Author Posted July 16, 2010 cheers vez im gonna give it a go this afternoon and hopefully im able to get it off lol might also come up with my own flywheel puller but iv got a spare incase it all goes horribly wrong .
Moderator Airhead Posted July 16, 2010 Moderator Posted July 16, 2010 You live in Alfreton...Granby's is your friend. Get a puller
Paulwhite Posted July 16, 2010 Author Posted July 16, 2010 You live in Alfreton...Granby's is your friend. Get a puller iv heard of it but dont know where it is lol
Moderator Airhead Posted July 16, 2010 Moderator Posted July 16, 2010 iv heard of it but dont know where it is lol I find that incredible, one of the best suppliers in the country IN YOUR TOWN and you dont know where it is!! OPPOSITE TESCO
Paulwhite Posted July 16, 2010 Author Posted July 16, 2010 nope still dont know where it is lol il get me m8 to take me down sometime yeah it is a bit bad.....as i said iv heard of it but havent seen it, unless your on about that car shop thats down the side street past the bus station?
Moderator Airhead Posted July 16, 2010 Moderator Posted July 16, 2010 nope still dont know where it is lol il get me m8 to take me down sometime yeah it is a bit bad.....as i said iv heard of it but havent seen it, unless your on about that car shop thats down the side street past the bus station? Granby Motors (Ilkeston) Units 1 & 2, Belfield Street Rutland Industrial Estate ILKESTON Derbyshire DE7 8DU Tel: 0115 930 0020 Tel: 0115 944 1346 Fax: 0115 944 7029 e-mail: [email protected] Sales Contact: Kelly Dunn Tom Cullen Opening Times: Mon-Fri: 9am -5.30pm Saturday: 9am - 5pm Closed Sunday
Paulwhite Posted July 16, 2010 Author Posted July 16, 2010 ahhhhhh you didnt say it was in ilkeston lol thought you ment opposite the tesco in alfreton lol
