how do you split a xv 125 engine?
hi peeps iv got to take the crank out of me xv 125 engine but cant get the clutch or the magnet off, anyone got a manual or some instruction?
the clutch has a wierd bolt and nut in the middle that both undo, and the magnet on the other side wont budge cause its a taperd, keyway shaft.
cheers.
.Paul.
cheers.
.Paul.
If its anything like most i have worked on you will possibly need a flywheel puller for the magnet (flywheel). Although i have used a rubber mallet to gently tap the flywheel whilst pulling it away from the bike, but i have broken magnets using this method. It best if you get a puller.
They come in different shapes and sizes and are not to expensive. Below is the type i have.
And the part of the clutch you are talking about is for possibly for adjustment, if you remove the springs it should come off,and the part you talked about should be attached to a long bar that protrudes into the shaft in the middle with a ball bearing after it that may roll out. Friction can hold the outer plate on quite well.
HTH
Vez
cheers vez im gonna give it a go this afternoon and hopefully im able to get it off lol might also come up with my own flywheel puller but iv got a spare incase it all goes horribly wrong .
You live in Alfreton...Granby's is your friend. Get a puller
iv heard of it but dont know where it is lol :D
nope still dont know where it is lol il get me m8 to take me down sometime :P
yeah it is a bit bad.....as i said iv heard of it but havent seen it, unless your on about that car shop thats down the side street past the bus station?
Granby Motors (Ilkeston)
Units 1 & 2,
Belfield Street
Rutland Industrial Estate
ILKESTON
Derbyshire
DE7 8DU
Tel: 0115 930 0020
Tel: 0115 944 1346
Fax: 0115 944 7029
e-mail: [email protected]
Sales Contact: Kelly Dunn
Tom Cullen
Opening Times:
Mon-Fri: 9am -5.30pm
Saturday: 9am - 5pm
Closed Sunday
ahhhhhh you didnt say it was in ilkeston lol thought you ment opposite the tesco in alfreton lol
