July 13, 201015 yr Hi Guys, I had to admit defeat with my latest project and ask on here for help. I bought a DT125R 2002 model with a siezed top end, luckily the previous owner had sleeved it so it was a quick rebore and piston to match, top end gasket kit and away i thought it would go, however when i kick the bike up, it takes a while to start, then when it does go it sounds very boggy and hasn't got the "ting ting" like a 2 stroke should have and as soon as i touch the throttle it dies. I'm a competent 2 stroke mechanic, i've eliminated all the usual suspects. Replaced the carb Cleaned the carb New plug Cleaned the airbox Fresh fuel etc..etc.. I noticed on this model, the carb inlet is not on the barrel but in the engine. My next theory is, could there be a leak in the engine itself due to a incompetent repair done previous to myself buying it. I haven't compression tested the bike as my tester wont fit ..lol...but finger over the hole, fires off with ease, easily enough compression to run it. Any help would be great.
July 13, 201015 yr Moderator I assume this is happening even with the choke on, because it is unlikely to even start without it?
July 13, 201015 yr Author I assume this is happening even with the choke on, because it is unlikely to even start without it? yes mate the choke has to be open it wont start without it even when warm! any ideas?
July 13, 201015 yr Moderator yes mate the choke has to be open it wont start without it even when warm! any ideas? Possible fuel starvation. Take off the fuel feed pipe from the carb and run it into a container, is there a good strong flow?
July 13, 201015 yr Author yup fuels flowing like a river lol cant understand it. i will say on the right hand side of the carb theres a 10mm threaded plug which looks like it should have something in it does yours?
July 13, 201015 yr Moderator yup fuels flowing like a river lol cant understand it. i will say on the right hand side of the carb theres a 10mm threaded plug which looks like it should have something in it does yours? No nothing in there, at a guess I would say that would attach to another carb on a twin cylinder bike, for the choke maybe. Dont you just love a challenge, still sounds like fuel starvation, I know you worked on the carb but could the main jet be blocked? What size is it by the way?...240 is standard
July 13, 201015 yr Could be the power jet circuit in the bottom of the float bowl. Just thought i would throw that in there. Vez.
