July 7, 201015 yr hi all i need a bit of help i got a '75 rs125 torque induction the other day and have just realised the front brake doesnt activate the brake light and on further inspection there is no switch on the brake lever to activate the light and there is not even a place for the switch, the rear brake does activate the light as it should, any help would be welcome, Thanks Chris
July 7, 201015 yr hi all i need a bit of help i got a '75 rs125 torque induction the other day and have just realised the front brake doesnt activate the brake light and on further inspection there is no switch on the brake lever to activate the light and there is not even a place for the switch, the rear brake does activate the light as it should, any help would be welcome, Thanks Chris it never had a front brake light switch ... it was not a legal requirement back in the day
July 7, 201015 yr Moderator it never had a front brake light switch ... it was not a legal requirement back in the day Hello hello, where have you been hiding Jim?
July 7, 201015 yr Hello hello, where have you been hiding Jim? I have had a bad year but never mind .. I'm still alive !
July 7, 201015 yr Author it never had a front brake light switch ... it was not a legal requirement back in the day oh right at least i dont have to worry now, wish id have joined the forum sooner thanks
July 7, 201015 yr r Yip , 1983 before it was legal to have front switch. so N/A. on pre 1983 bikes for M.O.T.
July 7, 201015 yr Author Yip , 1983 before it was legal to have front switch. so N/A. on pre 1983 bikes for M.O.T. i was wondering how it passed mot thanks
July 12, 201015 yr It might not need a front brake light switch but my '72 AS3 and '73 RD125 (torque induction) models both have them. There is a little plastic switch that lives under the alloy brakelever perch and is wired into the loom (in the headlamp bowl). The RS125 perhaps didn't have this as it was a single cylinder (budget?) model but the RD125 twin models definitely had a front brake stop switch as well as a rear.
July 12, 201015 yr Author I checked underneath the brake lever and there is no space for switchgear so I am assuming that it's not fitted as standard Thanks Chris
