Posted July 6, 201015 yr Yesterday i wantead to try the electrics on my fz 600 to see if every thing was ok after a year of not running, i replaced both coils with new ones, new re/rec, ing switch , i used one of the jumper packs to put some current in and every thing looked ok,i put a new battery on it today and have nothing working, checked earths, put old ing switch back on checked fuses and checked amps on new battery,what should i check now. solonoid if so how do you check them,what elese can i check, any help would be welomed.
July 6, 201015 yr Yesterday i wantead to try the electrics on my fz 600 to see if every thing was ok after a year of not running, i replaced both coils with new ones, new re/rec, ing switch , i used one of the jumper packs to put some current in and every thing looked ok,i put a new battery on it today and have nothing working, checked earths, put old ing switch back on checked fuses and checked amps on new battery,what should i check now. solonoid if so how do you check them,what elese can i check, any help would be welomed. double check your earths again,if you have a new battery and you have checked the amps and all is ok , its got to be and earth or a fuse , one question though why did you change coils ,reg/rec, ign switch, if was running the previous year , i would have just stuck a new battery first? double check the ign switch you may have pulled a wire , use your multi meter and check you have current running to all what you have replaced does anything light up at all lights indicators idiot lights,etc cheers Al
July 9, 201015 yr Author Al, changed coils because i had a low reading on resistence,and the engine had been replaced the bike was very difficult to start and did not run to good,the reg/rec was changed because the battery was not charging but had a good current from genarator, the ignition switch was changed because a lead had pulled out at moment no lights on any of the equpment im going to check side stand and cluch switch, no gear lever on a moment so could be a false neutral,any think else i can check with meters. thanks Dave.
July 10, 201015 yr Author The battery was new, topped it up with acid and charged it.do you know wat the reed switch does near the head lights this used to click when ignition was turned on.
July 10, 201015 yr Author Spent a few hours checking electrics, checked loom up to ignition switch,moved connector and volt meter died, replaced connections to switch and all ok , replaced ignition switch with old one one but nothing else works, lights, oil lght, neutral light,break light, etc, cleaned and moved earth ,power going to solonoid both sides , no power at coils, checked fuses and put volt meter across connections but all looks dead,how can this be if power going to ignition switch, have 8 yard skip on drive way only wife stopped me putting in there,rebuliding bikes is supposed to be a pleasure and a hobby but my bike is not at the moment, going to leave it and come back to it , any help would be welcomed
July 13, 201014 yr Author Ithink i found the problem, i had 10 min before i was going out yesterday an tried a new volt meter across fuses,as i pushed the probes into the fuses i could hear a crackling sound on the connections,the fuse carrier has been replaced at some time and replaced with mini spade conector fuses , replaced all fuses cleaned up fuse holder with wd40, i now all lights working power to coils, reg/rec is getting warm ,power to side stand,i just got to get neutral light to come on as there is no power going to switch i think its not in neutral as i have no chain or gear lever on it at moment,learned to take time when checking electrics.
