electrics dead
Yesterday i wantead to try the electrics on my fz 600 to see if every thing was ok after a year of not running, i replaced both coils with new ones, new re/rec, ing switch , i used one of the jumper packs to put some current in
and every thing looked ok,i put a new battery on it today and have nothing working, checked earths, put old ing switch back on checked fuses and checked amps on new battery,what should i check now. solonoid if so how do you check them,what elese can i check, any help would be welomed. <_<
double check your earths again,if you have a new battery and you have checked the amps and all is ok , its got to be and earth or a fuse , one question though why did you change coils ,reg/rec, ign switch, if was running the previous year , i would have just stuck a new battery first?
double check the ign switch you may have pulled a wire , use your multi meter and check you have current running to all what you have replaced
does anything light up at all lights indicators idiot lights,etc
cheers
Al
Al, changed coils because i had a low reading on resistence,and the engine had been replaced
the bike was very difficult to start and did not run to good,the reg/rec was changed because
the battery was not charging but had a good current from genarator, the ignition switch was
changed because a lead had pulled out at moment no lights on any of the equpment im going
to check side stand and cluch switch, no gear lever on a moment so could be a false
neutral,any think else i can check with meters.
thanks Dave.
erm? you have charged the battery up,tell me you have?
The battery was new, topped it up with acid and charged it.do you know wat the reed switch does
near the head lights this used to click when ignition was turned on.
Spent a few hours checking electrics, checked loom up to ignition switch,moved connector and
volt meter died, replaced connections to switch and all ok , replaced ignition switch with old one
one but nothing else works, lights, oil lght, neutral light,break light, etc, cleaned and
moved earth ,power going to solonoid both sides , no power at coils, checked fuses and put
volt meter across connections but all looks dead,how can this be if power going to ignition
switch, have 8 yard skip on drive way only wife stopped me putting in there,rebuliding bikes
is supposed to be a pleasure and a hobby but my bike is not at the moment, going to leave
it and come back to it , any help would be welcomed :angry:
Ithink i found the problem, i had 10 min before i was going out yesterday an tried a new volt meter across fuses,as i pushed the probes into the fuses i could hear a crackling sound on the connections,the fuse carrier has been replaced at some time and replaced with mini spade conector fuses , replaced all fuses cleaned up fuse holder with wd40, i now all lights working power to coils, reg/rec is getting warm ,power to side stand,i just got to get neutral light
to come on as there is no power going to switch i think its not in neutral as i have no chain or gear lever on it
at moment,learned to take time when checking electrics.
