Posted August 29, 200421 yr i have a tzr as a project bike and i want to make it really special.ive had one before,so i kinda know what im doing, but there'sa few urban legends i would like to staighten out.does the rear facing cylinder off a tzr250 vtwin,slot straight onto the 125 bottom end,without any mods?apparently it does, which would mean i could develop an under seat exhaust more easily.i also need to find a lighter flywheel/generator,and if anyone else can help with ideas(especially some formulas for exhaust design) any help would be much appreciated!!!thanx guys
September 26, 200421 yr one problem you may have not considered is where do you put the carb?if you put a rear facing barrel there will be no place to fit the carb ,the tzr uses a crankcase reed system so the carb and intake bolt to the crank case not the barrel
