June 26, 201015 yr hi i have a 2002 wr 426 with water in oil, does anyone know of a common fault like water pump seals etc, dont think its as major as head gasket because bike still runs good doesn't smoke and cooling system not pressurising, any ideas? cheers
June 26, 201015 yr hi i have a 2002 wr 426 with water in oil, does anyone know of a common fault like water pump seals etc, dont think its as major as head gasket because bike still runs good doesn't smoke and cooling system not pressurising, any ideas? cheers How much oil? All engines will get condensation especially on short journeys early in the morning or cold weather. IF that is what it is just take the bike for a good blast once a week.
June 26, 201015 yr Author well the engine must have taken all the coolant into the engine oil because i drained out a big quantity of milky oil, the cooling system was empty after about a 5 hour ride, thanks for your reply, any other suggestions?
