Yamaha dt50mx no low down power
Hi i am having problems with my dt50mx it has no power when going up hills on the flat it pulls but a slight hill it dies. I have changed the reeds,spark plug,repacked the exhaust. Any one know what my problem is thanks
I am thinking of putting a k and n filter on do you think this will help
How long have you had the bike?
has it been better than this?
Its a 50cc moped and not a powerful one at that...wouldnt you expect to downshift on hills?
Cant see a K&N making it better but you should do a compression test, it may need new rings or at worst a re-bore.
How many miles has it done? Ever had a re-bore before?
Have you ever dropped it and not bled the oil pump after?
I'm only asking because when I had one, way back when I was 16, I dropped it on a trail and didn't know about bleeding it after. It wasn't too long before a re-bore was needed, at least that's what Claremont's in Ashton said caused it.
Like OG said, they aren't powerful but mine was dreadful before the re-bore (15mph top speed!)
The compression test OG suggests should show it up.
Hope this helps.
I havent had it that long it has had a big bore kit fitted before i bought it. I think i have got used to it now because i can pull 40mph up a hill so i think it was just the lack of riding i have done but now i have got used to it its better thanks
