This post is 5294 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Our 1989 FZR 1000 Genesis. ran to work well. Pressed starter to move bike later and engine started to turn over then all electrics went dead. Battery and connections look ok, all fuses under left rear pannel look good. Where do we look next?
anyone any ideas?
hi never really played wit one of these but does it have a main relay?? are all the earth leads good??? hope you find it
the connections may look ok, but check them - if the battery connections are loose the minute you try to start it will die.
my fzr will do this if forget to tighten the battery terminals up properly.
  • Recently Browsing
