Posted June 24, 201015 yr Hey all you FAZER people. I just bought a 1986FZX700 the only problem with it is it leaks clutch mater fluid. It will not go int gear does it have to do with the hydrlic clutch does it need to be bled. Will air in the system cause it not to go into gear. It sounds like its going into gear but it will not move and I can push it like it is in neutral help me if you can. Thanks
