carb help
hello.
have dt 125 that runs rich,dropped to #110 main jet
have #7 ngk sparkplug
jet needle at leanest clip setting #4j13 will a leaner jet needle fix it?
use 32:1 oil/gas ratio
air screw 2 turns out
k&n filter clean
is the crank seal letting transmission oil to cylinder ? ...i plugged
off oil injector.
any thought to this issue would be helpful
thank you::
learaway
To quickly test the right crank seal put the transmission breather pipe into a jar containing white spirit, turps, kerosene etc.
Start the engine and increase the revs , watch for bubbles or any difference to the level in the jar. ;)
Why do you think its running rich? what evidence is there for this?
...Paul
...Paul
tenners comming out of the exhaust!
...Paul
............the sparkplug is very oily& the engine wont clean up @ mid throttle to full throttle
idle is fine and crisp until a bit past half throttle.
no actually it was.....it was pixi dust blowing out tis exhaust!
...Paul
