XS400 electrickery...
Here's where we're at: the left side of the ol' Green Machine has quit working. Swap coils, no joy. All mechanical adjustmens are in spec: carbs, point gap, valve clearance. Interesting discovery:
On the left side, I have @12vdc on the positive side, and nothing on the ground side.
On the right side, I have @12vdc on the hot side, and 12vdc on the ground side.
When I unplug the left coil from the circuit on the negative side, I then have 12vdc out. Good continuity all the way from the out on the coil to the points, just no sauce when it's in circuit.
Electercity: PFM.... Thoughts?
