June 14, 201015 yr Does any one know where the 2 rubber pipes that are connected to 2 tee connectors from the bank of 4 carbs go, the other 2 pipes coming from the carb 1 vacum pipe going back to the fuel tap and the other is the fuel line , the only thing i can find is a breather pipe connector at the front of the fuel tank. Having no air filters fitted or vacum pipes connected / crank case breather pipe cause the bike to be difficult to start and run erratic as is the case thanks Dave
June 14, 201015 yr Does any one know where the 2 rubber pipes that are connected to 2 tee connectors from the bank of 4 carbs go, the other 2 pipes coming from the carb 1 vacum pipe going back to the fuel tap and the other is the fuel line , the only thing i can find is a breather pipe connector at the front of the fuel tank. Having no air filters fitted or vacum pipes connected / crank case breather pipe cause the bike to be difficult to start and run erratic as is the case thanks Dave dave have you a photo of the pipes in question cheers Al
June 15, 201015 yr Author Hi i do have a photo but do know how to put them on, i think i have found out where they go ,the 2 pipes are carb breather or overflow pipes that just tuck down the back of the frame , the other pipe connect to the breather on the tank and not to the the fuel tap as i had thought and the other is the fuel pipe thanks for reply Dave
