June 11, 201016 yr Pulled the choke out, warmed up my bike, put it back in and rode to the store 20m away. Then started her up there and noticed my choke is stuck. Tried pulling relatively hard to no avail. guess its alright for now, bike doesnt really need choke in warm weather but would be nice to figure out whats goin' on in there be4 <60 degrees rolls around? Bike is a 1978 XS400E
June 11, 201016 yr Moderator Pulled the choke out, warmed up my bike, put it back in and rode to the store 20m away. Then started her up there and noticed my choke is stuck. Tried pulling relatively hard to no avail. guess its alright for now, bike doesnt really need choke in warm weather but would be nice to figure out whats goin' on in there be4 <60 degrees rolls around? Bike is a 1978 XS400E there's 2 indents in the rod which are held by ball and spring to hold choke in two positions. the chokes themselves are just brass tubes which slide in a cylinder with a rubber seal on the end. check the screws holding the "fingers" to the rod are secure and not sqiffy causing the jam (or marlalade) drewps
June 12, 201016 yr Author there's 2 indents in the rod which are held by ball and spring to hold choke in two positions. the chokes themselves are just brass tubes which slide in a cylinder with a rubber seal on the end. check the screws holding the "fingers" to the rod are secure and not sqiffy causing the jam (or marlalade) drewps heh, checked that area and i tried my hardest for 30m to see what was problem. the rod looked fine. the screws on the rod area looked fine... I tried pulling the left side carb part that the rod 'pulls' to see if that was causing the rod itself to jam and hence not pulling both sides open, (couldnt reach the right side to test that side out)... anyway couldnt pull it out, thought maybe it was the right side jamming up the whole thing. was gonna pull off seat/tank tomorrow to look around there/pull carbs off... Decided maybe while Im lookin round that area that i'd just set the idle mixture screws while i figure it out what the problem with choke is tomorrow lol... Tried pulling the choke on a whim right after that and bam it came out lol. weird. rub the rod with a lil' oil just in case. Thanks drewps!
