xs400sj carbs
can you help me with where to get a carb rebuild kit for the mikuni bs34 carbs, I've been looking and can't find a rebuild kit anywhere, I did find a place that does full rebuilds http://www.wgcarbs.com/index.php?option=com_content&task=view&id=14&Itemid=29 but they are expensive, I just want a kit that has all the O-rings, gaskets, needles and floats. or some where I can piece together my own kit, thank you.
O-rings: (for 4 carbs, but it's cheap, leaving you extras) You want the kit for mikuni BS carbs 80-84
Most everything else: http://www.mikesxs.net rebuild kit (needle, seat, gasket, and pilot jet plug) is out of stock
I got my needle and gasket here: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200474693262 I did have a problem though. With the clip that attaches the needle to the float they would not seal. They are just a hair too short. I removed the clip, and they worked fine. I didn't use the gaskets yet, as mine still seal very well.
I've heard questionable things about the rebuilds wiredgeorge did, and the setup he suggested.
