June 9, 201015 yr My brakelight on my 81 XS400 is stuck on. I have been mucking around with my rear brake switch with no success. Any suggestions? By the way, where is the brake switch for my front brakes? Thanks!
June 9, 201015 yr The front brake switch is in the brake lever perch. 2 going in, brown, and green/yellow. You could disconnect the rear switch, should have bullet connectors on it. If the lights still on, probably the front switch. Thenn try unplugging the front switch. I believe the plug is in the headlight bucket.
June 9, 201015 yr Author The front brake switch is in the brake lever perch. 2 going in, brown, and green/yellow. You could disconnect the rear switch, should have bullet connectors on it. If the lights still on, probably the front switch. Thenn try unplugging the front switch. I believe the plug is in the headlight bucket. That makes perfect sense..I will check it out tomorrow. Thanks!
June 9, 201015 yr Author I did get a chance to check out the headlight bucket and disconnected the front brake light connections. It did solve the problem..now I have to check out the switch. Anything I should take caution while taking it apart? I have had springs pop out unknowingly and that was not fun. Thanks!
June 9, 201015 yr Moderator I did get a chance to check out the headlight bucket and disconnected the front brake light connections. It did solve the problem..now I have to check out the switch. Anything I should take caution while taking it apart? I have had springs pop out unknowingly and that was not fun. Thanks! its just a sprung mom switch, very simple, 1 spring. I did strip one down but ended up getting new as it was worn out!
