1998 R1 faulty brake light
Hi Guys,
Just purchased a 98 R1. The brake lights are working when the front brakes are applied but not when I am applying the rears. Any ideas and could I repair this fault myself..
Thanks in advance....
"Any ideas and could I repair this fault myself.."
Rear brake light switch & yes.
Adam.
Hi Guys,
Most common fault in this case is the rear brake switch, you'll find it on the right foot peg, you can go and buy a new one, (not expensive) or you can take it off, take it apart, clean it inside, and put it back together, making sure there is a good clean contact patch inside, I do that to my at least once a year, for some reason they are crap, I gave up buying them few years ago, as they keep dieing, it's a quick and easy job, so give it a go.
Hope it helps.
