June 7, 201015 yr I just purchased a Yamaha 175 Enduro from an auction this weekend however, the data plate is unreadable and we dont know the exact year of manufacture. The VIN number stamped on the frame is 443-014469. Can anyone help please? Thanks,
June 7, 201015 yr hello, found some info on my bike. 1974 Yamaha DT175A Engine 1980 Yamaha MX175G Frame Serial number ID Yamaha ID dirtbike.off-road dot com
June 7, 201015 yr Incidentally, i had found this, didn't think it reliable to answer your question. From 'Yahoo Answers' no less. 1974 intro'd the "DT- Series". The 175's in 1974 became DT175A Engine Numbers: 1974>DT175A> #443-000101 1975>DT175B>#443-100101 1976>DT175C>#559-000101 ---1976 was the Last of the Twin Shock 175's 1977---there was NO "DT175" for 1977. The IT175 was introduced,,,and was 1st 175 Monoshock 1978>DT175E>#2A7-000101 The DT175 was Back,,,with a Monoshock. 1979>DT175F> #2N5-000101 1980>DT175G> #3J1-000101 1981>DT175H> #3J1-060101 1981 was end of the DT 175 Series IT175's ran thru 1983. They were the last 175cc 2 strokes,,,far as I know
June 8, 201015 yr Moderator Incidentally, i had found this, didn't think it reliable to answer your question. From 'Yahoo Answers' no less. 1974 intro'd the "DT- Series". The 175's in 1974 became DT175A Engine Numbers: 1974>DT175A> #443-000101 1975>DT175B>#443-100101 1976>DT175C>#559-000101 ---1976 was the Last of the Twin Shock 175's 1977---there was NO "DT175" for 1977. The IT175 was introduced,,,and was 1st 175 Monoshock 1978>DT175E>#2A7-000101 The DT175 was Back,,,with a Monoshock. 1979>DT175F> #2N5-000101 1980>DT175G> #3J1-000101 1981>DT175H> #3J1-060101 1981 was end of the DT 175 Series IT175's ran thru 1983. They were the last 175cc 2 strokes,,,far as I know Yes there was they just didn't send them to America. Kissing cousin of the CT1 sold from 75/6 to 78. Best shot on the vin number is a DT175A circa 74, a picture would help quite a bit. Can you read the engine number by any chance, should be on the top RHside of the engine under the carb.
June 8, 201015 yr Author Hopefully this picture comes through and helps. Thanks. Yes there was they just didn't send them to America. Kissing cousin of the CT1 sold from 75/6 to 78. Best shot on the vin number is a DT175A circa 74, a picture would help quite a bit. Can you read the engine number by any chance, should be on the top RHside of the engine under the carb.
June 8, 201015 yr Moderator Right a good clean std bike. Looks right but then 74-77 did look similar, the graphics though did change and with a bit of luck someone on here may be able to nail it down a little nearer i'll see what i can find. It does look to have the oversize front tyre that the A/B had for whatever reason but that isn't a definite to date the chassis from.
June 22, 201015 yr Looks identical to my 1975 DT175 ... Beyond that I'm still looking for info on mine....
June 22, 201015 yr Moderator Got it..... Its a 1974 DT175A the tank colour is yale blue and the frame numbers ran from:- 443-000101 to 443-025820, the engine number should be the same as the frame number.
June 28, 201015 yr Author Got it..... Its a 1974 DT175A the tank colour is yale blue and the frame numbers ran from:- 443-000101 to 443-025820, the engine number should be the same as the frame number. Thanks for your help!
