JORDAN-432 Posted June 2, 2010 Share Posted June 2, 2010 i recently had my engine out because the gears weren't right so i sorted that, now i think that the clutch is unbalanced. can anyone tell me the symtoms of an unbalanced cluth please. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted June 2, 2010 Moderator Share Posted June 2, 2010 Whats an "unbalanced clutch" ? Describe your problem. Have you had the balancer shaft gear off? Did you align the punch marks on re-assembly? It's all in the Haynes book Link to comment Share on other sites More sharing options...
JORDAN-432 Posted June 2, 2010 Author Share Posted June 2, 2010 well when i rev it over about 3k it vibrates quite bad. An unbalanced clutch is when the plates inbetween the friction plates aren't balanced because a bit of the plate has been taken off so you have to put them in evenly. I put them in as evenly as possible but just not sure whats wrong with it and thought this could be it. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted June 2, 2010 Moderator Share Posted June 2, 2010 I asked you about the balancer shaft, whats the answer? if you have had the balancer shaft / crankshaft gear off because you have had the feckin engine in bits........ Link to comment Share on other sites More sharing options...
JORDAN-432 Posted June 2, 2010 Author Share Posted June 2, 2010 no didnt go that far, i was going to split it as i thought there was a problem with my gears were inside the gearbox but it turned out to be the gear selector shaft. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted June 3, 2010 Moderator Share Posted June 3, 2010 no didnt go that far, i was going to split it as i thought there was a problem with my gears were inside the gearbox but it turned out to be the gear selector shaft. if you only had the clutch in bits then you may have replaced the plain (non friction) plates unevenly Link to comment Share on other sites More sharing options...
