Have just notice that untill my bike is revving over 4000rpm i have no indicators or lights or horn !!! Is this my battery ''Donald Ducked'' or not charging correctly ???
Help !!!
2strokeray
Help !!!
2strokeray
Sounds a reasonable diagnosis, have you got a multimeter to check it or know someone that has?
Should have around 12.5 volts with engine stopped and around 14.5 volts with engine at 5000 RPM
at a guess ;)
ok, have taken the battery off the bike and it has over 13Volts !?!?! Havent tested with the bike running yet.
My haynes book says it could be the generator stator coils ?
I have noticed a BLOWN glass fuse connected to the posative terminal wire of the battery, what is this fuse for and surely shouldnt be blown !?
Also a big drop in top end power ?
Yesterday i removed the reed plug out the speedo, bagged and sealed and placed it out the way, was all fine till this afternoon, would this cause me any problems ?
Any Help Gratefully Received !
Many Thanks
2strokeray
