When I use the idle screw to bring the revs up to 1200 at idle, it causes an issue. If I rev it up to say 4k, it will stick there or come down really slowly. I've tried all kinds of different variations, but it always will stick when I get the bike to idle at 1200. It is normal when the idle screw is out to let it idle at 1000.
Does this mean I should start messing with the pilot and balance screw(s)?
Thanks,
Aaron
Sounds to me like the idle mixture is to lean. Turn the screws in all the way- lightly seat- then turn them out 3.5 turns, reset the idle speed, and tryi it again.
Thanks, I will.
Aaron
