May 31, 201015 yr When I use the idle screw to bring the revs up to 1200 at idle, it causes an issue. If I rev it up to say 4k, it will stick there or come down really slowly. I've tried all kinds of different variations, but it always will stick when I get the bike to idle at 1200. It is normal when the idle screw is out to let it idle at 1000. Does this mean I should start messing with the pilot and balance screw(s)? Thanks, Aaron
May 31, 201015 yr Sounds to me like the idle mixture is to lean. Turn the screws in all the way- lightly seat- then turn them out 3.5 turns, reset the idle speed, and tryi it again.
May 31, 201015 yr Author Sounds to me like the idle mixture is to lean. Turn the screws in all the way- lightly seat- then turn them out 3.5 turns, reset the idle speed, and tryi it again. Thanks, I will. Aaron
