May 31, 201015 yr Hi all just wondering how to set up the sppedo on my sons 2006 xt125x ie what is the the favoured mode and how do you change modes. A copy of the hand book section would be appreciated as bike did not come with handbook. Many thanks
June 8, 201015 yr hi i have the xt25r and the settings are a..... you can either have it set to kmh or mph and my god trying to set it is like trying to learn the female mind if you send me an address ie email then ill send you a copy on line. you can also download and manuel on the yamaha site under downloads let me know how you get on kind regards Tim
July 10, 201015 yr hi i have the xt25r and the settings are a..... you can either have it set to kmh or mph and my god trying to set it is like trying to learn the female mind if you send me an address ie email then ill send you a copy on line. you can also download and manuel on the yamaha site under downloads let me know how you get on kind regards Tim Hey Tim i have been trying to fathom how to change the settings on my xt125r my battery ran flat and it swithched it'self from mph to kph do you know the secret of changing it back please tell me you are can you help please this is driving me wild Glasgowlad22
July 11, 201015 yr Try this- With the new battery connected the speedo should flash up enduro or motard. When it flashes from enduro to motard turn igniton on but dont start. When it flashes again to enduro press the blue mode button on the front of the left handlebar. It should revert back to the correct mileage settings. Hope this helps
December 7, 201213 yr hello i have the same problem i disconnected the battery and when put back together it changed to motard and when i turn it back on it doesnt give me the option to change to enduro any ideas?? thanks
December 7, 201213 yr hello i have the same problem i disconnected the battery and when put back together it changed to motard and when i turn it back on it doesnt give me the option to change to enduro any ideas?? thanks unplug both sides of the battery (i don't know why this works best but it does) for about 30 seconds then plug it back up now turn ignition on, wait until the mode u want is on the screen and hold blue button. this should do it.
